706 electrical diagram
I've been rewiring my 1964 gas 706 and am looking for a wiring diagram on the air filter restriction indicator and sensor circuit. Also I am looking for a schematic for the cigarette lighter so I can see where it is supposed to get it's power from. Thanks.
They aren't listed on there. I found the cigarette lighter gets power from the junction block. It was in the operators manual. I am still looking for the air filter restriction gauge and sensor circuit. Mine was wired with the power wire coming from the push button to the gauge, then from the gauge to the sensor, then from the sensor to I assume ground. I am not sure where the factory had the ground attached though. I am also not sure on getting power from the push button.
It looks like the cigarette lighter got its power from the starter solenoid on some models as well. This might be a better place because I could run a lead to it with an in-line fuse. Plus it would handle the amperage better.
