720 crankshaft thrust washers
greendiesel
any old timers out there ever see a brass type crankshaft thrust washer on a 720 diesel ? took one apart and it has brass thrust washers. all the outers i have ever taken apart (or seen) have been the fiber type. what the heek is this?
I know of several folks who made their thrust washers out of brass, and they claim that they work and hold up well. I have made them from circuit board phenolic, which what that original fiber material is. I may try some brass some time and see how it works.
This is interesting... I am about to pull the flywheel on my 70D to change a leaky oil seal, and I'll bet the thrust washers are worn pretty thin. I hate the idea of putting phenolic ones back in, although it was good enough for Mother Deere back when.
What thickness of brass stock is best to cut new washers from?
The phenolic one from Deere is .056", so I would probably choose 1/16" brass sheet, provided you still have enough thickness in the shim pack to remove that extra .013" you'll gain using the brass. Otherwise, you might have to find something a bit thinner, but that can be tough to find in other than fractional thicknesses. Plus, in small quantities, brass isn't all the cheap either.
If everything is set correctly, the phenolic lasts for a long time. It's when you let the endplay get too large that the carnk hammers sides ways and cracks them. Typically they lose their tang and then spin into oblivion.
You weren't kidding... McMaster-Carr has brass sheet in .050 and .062, as well as 1/16", but a piece big enough to make a couple of thrust washers out of costs $36 plus shipping! If the phenolic pieces lasted (presumably) 57 years, I guess one more set will last the rest of MY life...
