730-830 2 cylinder
The free parts book on the JD web site has or did have a cross reference for common parts .
Injector tips for the 70/80/820green dash differ vs the 720/730 vs the black dash 820/820/830/840
The black dash 820/830/840 and 720/730 use the 13mm pumps .
70/80/greendash 820 use the 10mm pumps .
There are also different spray angle on the various tips to match either the wide and shallow piston dish or the later deep and narrow piston dish.
I had looked up the parts numbers and they were different just didn?t know if I could use 830 pumps and be able to have it run ok.
There are about three different shops that advertise in green Magazine that do pump and injector work. Could do worse than send the pumps on thier mount and the injectors . To have everything calibrated , leak free and spraying on spec.
