730 Case electrical issues
Gkrob
730 Case tractor, Gas.
The only way this tractor will run is if I run a jumper wire from battery to coil. I have tried everything I can think of to get it to run. I've even replaced the ignition switch to no avail.
Does anyone know where I can get a decent wiring diagram?
I'm thinking I will have a broken wire somewhere but need a color coded wiring diagram.
Do you have battery voltage at the switch?
Did you check for a bad resistor or resistance wire between switch and coil?
Trace wiring from battery connection at start solenoid, to switch to resistor to coil
Well if it runs hot wired that say you have a bad wire between the battery and the coil or a bad new switch. Time to trace wires and find where one is bad
Hi:
As others have said, bad switch or bad wire or resistor. You already know the tractor will start if you jump the coil, so now it is time to check the switch with a test light or ohm reader. In the off position there should only be power to the battery wire. In the on position there should be power to battery and coil. In the start position you should have temporary power to the starter position as well. That will tell you which wire you are looking for and then you just need to trace it to find where it goes. Remember the wire could be broken inside the shielding or you could have a bad junction box.
GK, if you do not have power to the dash at all on the back side of the gas tank bracket under the tank there is a circuit breaker that I have seen a few fail over my career, take a test light and check for voltage on both sides of it. Most tractors do not have one and I do not know why Case decided that some need it and some don't. A place to start checking then go to the switch.
This is a diesel print, but this may be of some help, along with others that have posted.CM
Sounds like a bad safety switch,clutch pedal,gear shifter,PTO in
gear? Any would stop it from starting.
