730 Case Steering
Olie
I have a half around of play in the steering wheel (this one doesn't have power steering)how can i get the play out of the gear box.
Thanks.
You can adjust the steering sector under the fuel tank, but more than likely you have a bad bearing in the sector gearbox itself. On mine it was the bottom bearing bad from water getting in around the top seal. Take the old parts to a good bearing supply and they should be able to match numbers for new ones.
