I was previously piggybacking on another post on here, but thought I better start my own thread to reduce confusion.
The problem:
I was using the loader on my 730 (741) to move a mower, it lifted that well, set it down, drove in to rock pile to haul rock and have almost no hydraulic power. The loader won't even lift itself empty, but the cylinders will work back and forth a little. The 3 point, which I had used 2 days ago to lift a backhoe, now will barely lift me standing on one arm (it moves very slow). I don't notice the hydraulic/gear whine I used to when I let out the clutch in neutral. PTO seems to work normal, haven't had a load on it since hydraulic issue, but the PTO clutch handle feels normal.
A bit of history:
This tractor has typically been slow to "pump up" the hydraulics. You'd start the tractor, then wait a bit (20 seconds? depends on how recently it'd been run, ambient temperature, mood) before I'd have loader or 3 point power. We've been using this tractor as a weekend warrior for the past 5-6 years, but previously it'd set for probably 10 years with a head gasket/stuck engine problem. When my dad and I revived it, we had similar challenges with the hydraulics. Dad went through the control valve with little improvement, then it just kinda started working progressively better. One set of remotes seemed to work better than the other. I used the good set for the loader, which would lift the front of the tractor, or lift a bucket load decent, and the second set I used on the back blade rotate. One direction it always worked well, the other direction it sometimes worked well, sometimes it got really slow, but it was adequate for what I needed.
Some of these symptoms may not be at all related, but, better too much information than too little, right? I do have an I&T manual (of minimal help) and I've found the online parts book resources.
In attempt to troubleshoot / diagnose the issue, I have:
-Checked and topped off the hydraulic fluid (a little milky, nothing too bad. No noticeable air bubbles. Did full fluid and filter change 18 months ago)
-Changed the spin on filter over the axle (I was a little surprised it didn't have more fluid in it, tractor had been run within an hour)
-Checked hydraulic pressure at the remote quick connects. About all I got was a gauge flicker, I can feel the hose move a little, but nothing like you'd expect.
-Pulled the pump. I noticed the pump turned decent one direction, the other was very difficult by hand and I didn't want to put a tool on the gear.
-Blown air in the pump pickup port in the tractor in attempt to clear screen obstruction, if any. (through #3)
In the process of writing this, I had another thought. Is the gear on the end of the pump shaft (#4) supposed to be beveled or bull nosed to help with installation alignment? Because this one is. The roll pin is intact, but the gear seems a little loose on the shaft. There was a little black grime on the dipstick magnet, for what it's worth.
Something I haven't done yet, and I think is my next step, is to take the pressure line from the pump and direct it into a bucket to check flow.
-If there is good flow, where do I go next?
-If there isn't flow, can I run the tractor without the pump in the hole to make sure the pump drive shaft is spinning? Are there any other steps I should take before dropping the tail housing off the tractor?
I have no problem doing the work, but I want to do my best to diagnose it before pulling the tail or something else labor intensive to no avail. I'm a little hesitant because I heard lots of fluid gurgling around when I blew in there.
Sorry for the lengthy post and list of questions, and thank you for any and all help / insight y'all can provide.
Joel
The problem:
A bit of history:
Joel
