Country Nate
I was running a haybine yesterday and there is a "clunking" noise only when the pto is engaged. There are no noises in the back where the powershaft comes out. Other than the noise, the pto works fine. It seems to be up front on the right side by the clutch??? When the pto is not engaged, there is no noise. When the pto is engaged with nothing attached there is no noise. The noise gets alot worse when going around the corner to the right. The noise is there when the clutch is engaged or not. The flywheel is not loose, and there seems to be no other problems with the tractor. All fluids have been checked and are ok.
Has anybody had any experience with this before? Thanks in advance.
