730 diesel flywheel
Gary Hunter
I need a flywheel for a 730 diesel I think the casting # is 3570R. Does anyone close to Ga.have one and what would it cost.THANKS FOR THE HELP!
It is cracked pretty bad and someone tried to braze it and made a mess of it.I have anotherone that has two small cracks in it.Can these things be repaired?Thanks,Gary
Boy, Gary, that is one thing I would not try to repair. That"s a lot of mass flinging around at 1200 rpm, and it could get tragic real fast if it let go. Now if you have a good flywheel, but with bad splines, you can go the route of a Tap-R-Lok flywheel collet mount.
HTH
Frank
Gary,
Just bought one for our 730 same casting #. Found several used but after freight decided to go taper lock. McGrew Tractor parts New Paris IN, sold cash $750. This was just a month ago. These are the ones case and made in TN. Joe
