730 fuel consumption
HP Smith
I'm looking to buy a Case 730 or 830. Can any tell me about the diference in fuel consumption between a gas or diesel?
Thanks,
Harold
The specific fuel consumption per horsepower is about 14.88 for the diesel and 11.65 for the gasoline engine.
The 730's in both gas and diesel are slightly more efficient than the 830's... Gene
Mr. Smith,
I have a 730 Gas Comfort King. For a gasser they ain't bad!
I have done extensive fuel consumption testing on mine. Last year I used it to plow, disk, plant corn, pick corn, cut hay, and bale hay. The average fuel use for the year was only about 2 gallons per hour.
Pulling a disk pretty hard it will use about 3 gallons per hour. Baling small squares a little over 1 gallon per hour.
My points and timing are set correctly, and it like premium gas (93 Octane).
I love the tractor.
I bale hay with 2 identical balers with accumulaters behind. In 08 I ran a 730 gas, and a 830 diesel. It worked the snot out of the 730. Governor would drop wide open every stroke of the plunger. It consumed a full 4 gallons an hour. The 830 diesel would give a little puff of diesel smoke with the plunger stroke. It took right at 1 gallon an hour. Did not take long to replace the 730 with a 870 diesel. For a chore tractor the gas would be better though. Starting and stopping is very hard on a diesel. Depends on what you will be using it for.
We sold a lot of 730s and 830s. The 730 had a very poor weight to HP ratio. On the hills of central NY 730s labored to pull themselves up a hill. The good thing; we didn't have to bolt on pricy weights. The 830s were a much"snappier" tractor because they were no heavier and had more HP.We sold both models as 4plow tractors. The 730 was fine for the dairy farmer who fed a lot of hay. It had the weight to handle heavy balers and haywagons on our hills. If we were selling a 4 plow tractor to a farmer who fed a lot of grain crops and tilled land, the 830 was much better suited. Fuel consumption of a 730G plowing or discing was 4++GPH. 830G about the same, but covered more acsrs. 830D used about 3GPH+-The COM trans. was a great asset in our neck of the woods. We wished that CASE put them in 930-1030s. Found out why they didn't in 70 when the RPS34 transmission came out.
I'm confused. When you say an hour do you mean an hour on the clock or an hour on the tachometer? I do my calculation based on an hour by my watch. An hour on my watch is usually about 7/10 of an hour on the tach. If the correct way to calculate fuel usage is by tach hours then yea add another gallon to my calculation. If not, then I don't get it. I can put 5 gallon of gas in my tractor and run a small square baler for almost 4 hours (by my watch). I know because I've done it! I'm running about 1100 or 1200 rpm's. Yea I know the Nebraska test on the 730 in 1960 says rated rpm's 4.9 gallons per hour, but I ccould never get mine to use that much. Mabie I just baby it :<)..
I don't know what kind of baler you have, but 1100 to 1200 RPM does not make much hay. How many tons an hour are you getting through for that gallon? When I am baling hay my tractor has to run at full PTO RPM to have enough power. Baler runs 70 strokes/minute, 10 strokes per bale = 420 70# bales per hour. That comes out to over 14 tons per hour per baler. How many tons are you makeng for your gallon of gas?
I have an 830 Series Model 841 gaser. Pulling a six foot rotary cutter in low range fouth gear, it uses just a little under three gallons per hour. The carburator is ajusted per the owner's manual. Points etc are in excellent shape and the timing is right on. It is really a strong tractor. I cannot get it to stall or stumble in the thickest of cover. It starts very very well. Hope this helps.
NATE YOU CERTAINLY ARE CONFUSED. You could start your tractor up and throttle it op to rated RPM and let it set there. It could set there all day running at rated speed, about 2150 RPM at 540 PTO RPM It probably would set there and only burn a gal. per hr. (60 min.) NO WORK DONE. Hook it onto a plow and pull that plow at the "rated RPM for the same amount of time. WORK PERFORMED, Burned more fuel to do so. If you dropped that plow into the ground with engine running at 1100 RPM it would probably stall. The more work you demand from the tractor the more fuel it will use!
Our 730's Gasoline tractors use about 4 Gallons a Hour on a Plow,4-16's the 930 Gas on the forage Chopper 5 1/2 -6 per hour chopping Haylage [ Clock ] this was back in 87 or 88 /when the 930 Diesel and 2090 were plowing & planting do to a Very Wet Spring . We have sence added several other 70 & 90 series Tractors up to 2870 & 4890,so the gas ones are used as wagon haulers,Our 970 Gas that we Bought a few years back had 3304 hours on it and now has 3388 hour on it ,runs good just hate the shifting 8 speed,They Used longer Levers than the 870's makes it had to get used to.this tracto has never been used enought to know how muce fuel it would burn,i wounld thing the same as a 930.
This is the rig I run baleing.
At 1200 rpm's it will crank out enough bales to keep the guy in back hopping. I don't know the tonnage per hour but we can put up 500 in an afternoon with a little help. And yes it will use a little over a gallon an hour (by my watch) while doing this. My uncle had a Case 800 for 30 years and with the 251 cc gas engine in it would do the same thing. I have never run my tractor at rated rpm speed baling hay. I guess I do baby it.
Ad Case Guy, I understand when they are testing at rated speed they are pulling to use the 4.9 gallons per hour. It seems I'm not the only one confused though because you didn't answer my very simple question. When you calculate GPH do you use a tach hour or one hour of time? Big difference. There is no need to get hostile here, everybody knows I don't know everything and neither do you
It's like the others said, the harder you work it, the more fuel it'll consume per hour. Here's my 1966 730 gasser.
Hay NATE Sorry you missed it , but I did say gal. per hr.(60min) You have a nice 730 there. What type of animsls do you feed the hay to, dairy-beef or do you sell the hay?
Ad Case Guy,
Your right, I did miss it. Sorry about that...
We use it to feed out Holstein steers, and also we have a flock of sheep we sell meat lambs from. Never have any problem selling the extra. We put up about 4000 bales a year.
I also grow ear corn to gring up for them.
Nate I will second your Practice .., Thats how I usually run my squareBaler ,,, Rarely do I crank the NH 268 to 540 ,, 1400 engine rpms on 430 , or 1/3 to half throttle on SC or DC ,, Now the NH 846 round baler is usually running at 540 after bale is started ... I do know the 730 gasser will Drink more than a DC ,,, As others state , It depens On What You are asking it To Do ...
I was always under the impression that an hour on the meter was 1 hour time at 540 rated engine speed. Or if the tack was at the 540PTO mark it would turn an hour on the meter in 1 hour. So at 1/2 PTO speed it would take 2 hours to turn 1 meter hour.
