fixerupper
The latest thermostat I ordered came in the mail today. I guess it will have to work. The tractor needs a 2 7/8" outside diameter 260 degree thermostat that seems to be made out of unobtanium. This thermostat that came today is the 2.49" diameter thermostat NAPA crosses to but a 2 7/8" OD fender washer has been pop riveted to the thermostat to make the working OD factory size. This one is 180 degree. That is OK but I still wonder if this thermostat will flow enough. The only way to find out is load it down on a hot day. That might not ever happen though. I hate to see a tractor with a brand new radiator heat up because the coolant flow has been throttled by an undersized thermostat. You can read my first post to find out what happened with the first two thermostats I tried out.
