old red guy
Getting close to finishing up on the resto of a 730 gas. The 12 volt delco coil is banged up. Went to O'Riellys to get a new one and they act like a delco or this GM coil is hard to get. Plus what is the differnce in a coil with a resistor and one without. Is this type of resistor the same as the step down ceramic one on the tractor. One last thing is how do you test the old resistor to see if it is good. thank you
Test the resistor with an ohmmeter or just one of those continuity tester lights you can buy in most car parts stores. Wiggle the ends if you have continuity to make sure there are no intermittent connections. The reason you want a 6 volt coil is because the resistor is taken out of the circuit when the starter is engaged and this gives a hotter spark since the battery voltage will be drawn down with the heavy starter load.
