thornapple
This message is a reply to an archived post by MBdeere on December 14, 2010 at 15:28:54.
The original subject was "730 pony motor".
I called Glen and he said they always had a used ones laying around for the motors they rebuild and did not have a source that I could go to. I checked on the Mercury outboards and found nothing. I finally found a 110 degree thermostat on ebay for $26 that I made work. They are for the Chrysler Force 80 to 140 hp marine engines part # F 528068. The base is smaller in diameter (aprox. 1.375 in). I used the outside of the old thermostat for a washer and inverted it so the new thermostat would sit down low enough to clear the cover. I ground a little off the inside of the cover for clearance but I think the gasket would have given me the needed clearance. Note: I did solder the new thermostat to the washer.
