730 tank valve removal
I have to replace the vapor valve on my 730 LP. Is there an easy way to do this or do I have to pull all the sheet metal and the tank. Is there a trick to it? Can I remove or move the dash panel instead and access the valve from the front without removing the tank and most of the top of the tractor?
We did a similar procedure to remove the shift quadrant but in your case.
The tank feet actually sits on the dash. So you should be able to support the tank with a engine lift, and disconnect the dash from the tank AND the shift quadrant. The Throttle linkage, choke, and wiring will need attention too. Also steering wheel removal is necessary.
I just finished do that to my 730lp. I removed the sheet metal to diconnect the sterring coupler unbolted the back of the tank and supported it up with a small block under the tank removed the bolt from the quad range and slide the complete dash back.then installed the new valve from our local LP dealer.. If John Deere would have made the valve stem holes in the dash about a 3/8"" larger , the valve could be taken out very quickly. I then power wash it and repainted it and am now waiting for my decals from Jorde"s..Good Luck Ben.
Thanks boys. As I figured, it's not going to be simple. Interestingly, John Deere, if they manufactured the valve, ( or whomever made it)locked the threads on the packing nut by driving a pin through it. If you try to remove just the packing nut to replace the seat or washer, you booger up the threads. The entire valve must be replaced. Time to dig in, plowing time is coming up.
