7500 hydraulic hoses?
Cutlass327
Does anyone have the specs for the hoses on the implements? I need to replace 2 on the hoe arm and one on the right outrigger. If I can have them already made up and ready to install, I won't have to worry about losing as much fluid or water contamination if it rains while it apart.
You are overly worried. Just take them off and cover any open ports.
TOH
I agree with TOH.
Your New Holland Construction Equipment dealer may have a listing of hose part numbers and how they are made up, hose size and length, fittings, etc. If they do, they could make them for you, I doubt they will give you the info.
Another question I forgot to ask, saw it today as I was looking it over..
It had some lines along the boom, one was cut and blocked off. It has quick connects on each end.
Is this being blocked off something dangerous? Should I make them loop? I don't plan to ever need these lines, as I don't have a thumb or jack hammer..
