Specifically what dimensions do you want? There's a 6030 here, and a friend has a 7520, and I may get by his place tomorrow.
I am working on a 4010 I built a bigger frame on it n put a 466
engine in it I need a bigger hood but don't want to go as big as
a 6030, I'm thinking the 7520 hood is a bit narrower than the
6030, I'm going to change all the sheet metal
You can put a 466 in a 4010/4020 without stretching the frame,,let me know if you want more info,,but of course you already made a longer frame,,Darn it
a 4320 or 45/4620 hood might be a good fit. They are longer and wider but not as large as the 6030/7520. The early 7020 hoods would be the same as 45/4620 as well.
Many things need to be changed when you go for longer frame instead of re-working the front pulley and fan set up...steer pipes, pump pipes, and the hood...this is why I came up with the pulley/fan modifications...makes a nice clean conversion..
I'm lookin to put this hood on a tractor a pull, the turbo is big enough it will not fit in a milk crate, now I have a bubble built up over it I want to keep the classic look and have enough room under the hood, I'm thinkin the 7520 sheet metal will give me the room I need
I see what your thinking,, but the 7520 hood is way bigger, that's for sure,,it will probably fit like a saddle on a sow, the 4320 hood would be a closer fit,,but they are kinda rare..
The 7520 will have the big air cleaner door in it too,,,I have a new 4955 hood hanging here in the shop, but that's not the look your going for..
I know what you mean.. I got this hood out of a Deere Depot dumpster,,nothing wrong with it,, I was going to put it on an old wheel ditcher, then didn't,, if any one out there is interested in it,,here it is..
The only difference between a 6030 hood and a 7520 hood is the 6030 has a hole out front for the fuel tank neck. If not for that, they are identical and fit precisely the same. I can get exact dimensions if you still need some.
