756 pto quit working
herk
Hello what is the most common cause that the pto would just stop working ,pump in pto unit ? coupler moved or broke ? hub on pressur plate stripped out ?? I have had this happen a 400. Thanks Bryan
Ya sheared the tiny pin holding the two halfs of the valve stem together. The valve drops out the bottom and that pin ya need to get them from I H . Buy two or three .
I've replaced that tiny pin with a needle bearing roller from a U-joint cross and bearing . Find a needle roller that is the same diameter as the tiny pin, grind it down to length needed, insert it and reassemble your PTO control valve. Never had one of the needle rollers break in the valve.
While your looking for that perfect needle bearing ya could drive to the dealer and get what ya need and buy three place each of them on masking tape and fold the tape over and write on the tape PTO PIN . Setting in the glove box of my 3500 Dodge in the glove box there are now down to five in a strip of masking tape That pin never breaks till ya need the pto to work . In all the u/joints i have replaced i have never found tiny needle bearings that small . and a brad nail is to soft.
