Posted this to RP, posting here for a few more looks.....
A little time today before baling some squares and I pulled the gas 756 out to do a tune-up on it. New plugs, solid core wires, new distributor
cap, dust cover, rotor, condenser and points. Also put on a new ignition coil as the tractor would occasionally just shut-off when warm and all
signs pointed to this.
Old plugs were fouled bad. Old wires were on bad shape too. Points pitted too.
However it started and ran.....
With the new stuff in place, the tractor will not fire.
Couple of questions. Ignition coil - negative side should go to the distributor? Should it be a 6 or 12 volt coil? External resistor is somewhere
in the wiring harness under the dash?
The old coil is an IH coil, p/n 396546-R93. It says on the label 12V with RES, or 6V. The coil I bought (or was given at the parts counter) is a
12V no resistor. What is the correct ignition coil for this tractor?
I've got plenty of gas and air, but no spark as best as I can tell.
Any ideas as to what's wrong? It will be next week before I can look at the tractor again.
i was kind of hoping to put this tractor on my JD348 baler with wagon in tow, didn't work out. Haying is over for us this year, maybe 2018.
Thanks!
Thanks!
