Working on a neighbor's Jubilee. Was running but stalled from too high a gear going up hill and won't start. No spark to the plugs. Did a quick ignition tune up as it hadn't been done in a while - new cap, points, plugs, plug wires and copper flat conductor in distributor (old one cracked). Had a new rotor but it just fell apart before even installed so used the old - it looks fine with no visible cracks, tests good for continuity across spring post and tip, coil tested ok on primary and secondary and I get a spark out of it. Tried a new one anyway - still no spark.
I have spark at the points and can watch them fire, distributor shaft is tight and spinning, rotor turns. The coil is triggering and I have spark at the center post of the distributor but not to the plug terminals/plugs. I verified that at TDC the rotor is pointing at the #1 terminal so the gear seems ok.
It was still 6v and I'm going to convert as soon as I verify it will run so I disconnected the generator (hasn't worked in years), the old dead 6v battery and the voltage regulator and put a 12v coil on it. Acts exactly the same. Spark from points, coil triggers and spark at the center post but it's not making it to the outside terminals of the distributor. I'm at a loss, it must be grounding out somewhere in the distributor but I don't see it...
Bottom line, tried two caps, 3 coils, 2 sets of plug wires, direct wire to the coil from battery positive to test.
Any idea?
Any idea?
