7635 brake (s)
ozarks
Hello all- foot brake trouble on 7635
--lost fluid in reservoir--warning light came on--topped it off and ran for quite a while, then was low on fluid again---topped off and soon lost all pedal--went all the way down--brother brought in--filled up and bled brake system per operator manual-- RH side ok--LH side fluid goes way quick-- master cylinder or LH brake problem??--Never been into one of these this deep--thanks
If brake oil is disappearing it?s gotta be a brake piston seal problem. A master cylinder problem would put brake oil on the platform or floor if oil
was leaving the system. You are using brake OIL and not automotive brake FLUID?
(quoted from post at 18:43:48 09/25/18) Wheel cylinders. You don't want to hear it, but you will need
to pull the axles and yes do both sides.
Thanks to all--just wanted to be sure--will do !!
