7635 NH 4x4
Jim Wendt
Location
Zumbrota, MN
I have a 7635 that is the hardest starting tractor if it is below 40* you better have it plugged in for a couple of hours and it doesn't hurt to have the charger on also. The battery is only two years old. This tractor has always been this way. I would also like to give it a little more soup. Any suggestions. Less than 4000 hours, it is basically a chore tractor does some seeding in the spring and hauls grain in the fall, plows snow in the winter.
I have a T5050 that was that way since new. Loosen the 3 nut that hold pump on and rotate pump. Seem to help mine a bunch. The little 4 cylinders are all very cold natured. I’ve had 2 of the 6 cylinders and they both I’ll start below zero without being plugged in or heated
