770 industrial rear end
T Welch
Does any one know what row crop final drives will bolt up to a 770 industrial trans case do i also need bowl gears for same axles? thanks
Differential and transmission are all one piece housings, so what do you mean by 'bolt-up'
There was only one bull gear used for all 770 tractors, except for the Hi-clearance model.
There were two different ratios of bevel ring/pinions sets. Orchard and industrial used a higher-speed set than the normal Row-crop tractors. They are interchangeable, as long as you replace both the transmission output shaft and differential ring gear.
