770 pto clutch
Rice
I put in a 2nd hand clutch in my 770. My question is, should the lever slide into on position or kind of pop into on. This one kind of pops in. Wondering if it needs adjustment.
Thanks!
Rice
It's an over center clutch. It needs to snap in. If it just slides into position without a good snap to it, it's not set tight enough.
Sounds good, like you have a good unit, don't be afraid to grease that grease zerk!
Keep those old parts, shims are pricey, and if u clean them up and mic them, there are different thickness ones. Keep all three sets equal.
Korves, Maibach, Welters farm supply, Jerry Stair ag parts.
All good places to get parts, or advice. GG
Thanks!
Hey GG, if you could send info on fabricating pto lever setup for power traction, I'd be much obliged! :)
Rice
Will do,
We made one lever for my 77, that previous owner installed the hydra hitch onto.
Father in law has an 880 with the hydra hitch, now we have a project 880 with power booster and power traction hitch too.
We used a transmission shifter from a 77 parts tractor, some torch and heat and a good vice.
Lil welding at the pivot joint. Poof. New pto handle. GG
