JAC FARMING
Working on a 7700 thats been sitting quite a while. It runs on the first 3 cylinders but not the last. Motor was locked up due to water in last cylinder and i dumped pb blaster in the wholes and worked it over with a bar for a couple days and got it running. The injection pump is doing what its supposed to. If i crack all the injector lines it dies down except on 4. But it does shoot fuel out. I switched the injectors around and that didn’t work. Pulled valve cover and it was kind of rusty on top of cylinder 4 but the valves are doing what there supposed to as well. I filled up coolant and oil isn’t milky and coolant doesn’t have oil in it at least at the moment. And it does have compression. How much i have no idea i cant get the compression tester to hold it just blows the cork gasket out everytime. So ideas on what could be wrong. It starts ok kinda but it revs up kind of slow because of the dead cylinder. But for only 3 cylinders it seems to run smooth.
