Jyatesmp
Looking at buying a 7710 but having trouble decoding the numbers on the plate. Can someone decode, explain how to decode or show me where to decode the numbers.
Ill attach a photo. Let me know if you need me to clarify the numbers. Thanks.
The number labeled "Tractor Number" is the serial number. You cna look the serial number up here or on tractordata.com to determine what year it was made.
"Unit Number" is the code for the date that it left the assembly line. You need to know what years a particular model was made to know which decade(s) the date code might be for. The first digit is the year within the decade. The second character is a letter, and it tells you which month, A=Jan, B=Feb, etc, except they skipped I so after H=Aug it jumps to J =Sep and finishes out with K=Oct, L=Nov and M=Dec. The next 1 or 2 digits is the day of the month and the last character is a letter that tells you which shift wa on at the factory when it left the assembly line A-First or midnight shift, B-Second or day shift and C-Third or afternoon shift.
"Model Number" is a series of numbers and letters that tells you the model of the tractor as well as the type of engine, transmission and PTO it has. The model number should start with either FC3 or FC4 if it is a 7710.
The other numbers on plate the are date codes for when the individual components were assembled, engine, transmission, rear axle, hydraulic lift system and hydraulic pump.
Post all the numbers you can find back here and we can tell you exactly what they mean.
Thank you so much.
