Roy Ward
Need a little help on a problem.
After running a few hours you hear what sounds like when you use to hear your fan belt squeal when you turned the steering wheel all the
way to the right or left on your car.
If your doing a lot of sharp turning with the tractor it starts sooner than if your going straight. If you stop the engine for a while
and let it cool down when your start back up the squeal stops for a while.
Any ideas what I should look at.
Thanks RickB
Last year the outside grove of the belt stripped off. I have noticed the belt jumps pully groves. I didn't replace the belt.
I'll take care of that.
