8 cylinder simms pump help
bryan bailey
Looking for info on getting more fuel out of an 8cyl simms pump around 400cc anyone done it? Also does anyone have a reasonably priced p pump thanks Bryan
Yes I do but trying to stay with the simms if I can to avoid the adapter and expense but if go to a p pump that is the one I will use
Back in the mid 80s I helped a neighbor with putting modified 11MM Bosch plungers in a Simms MF 1155 pump block, reground the anti-reversing cam and cut the weight set to reach 5000 RPM. The JD 8850 pump would be easier, plus you could go to 13MM plungers also.
