8 volt battery
Starts easier.
I worked on a Super A for a friend not long ago.
Had an 8 volt battery and cranked and charged very well.
More power.
Voltage gets through poor connections better.
As well as spinning the starter better.
The old 6v systems were built strong enough to handle the 2 extra volts.
Not sure what happened for light bulbs tho, do they make 8 volt bulbs?
I don't think anything came factory 8v.
They were intended to give a 6v system just a little extra spin.
Unless the regulator was adjusted up, all it would turn into is a partially charged 8v battery.
I bought an antique tractor, circa 1938, this past spring that was set up for an 8 volt battery. I took the 8 volt battery out and put a 6 volt back in it just to make the tractor more original. This tractor won't be used in the winter and the 6 volt starts it just fine when the weather is warm. Ironically, the charging system wasn't working when I bought it, the generator isn't the original one anyway, but it shouldn't take too much to get it working back at 6 volts. BTW, I'm looking for a 6 bolt battery that has posts on both sides, like the one shown. Anybody know of a battery manufacturer that has posts on the same side, instead of opposite corners?
To the OP's original question, 8 volts makes it start easier when the weather is cold, but the old mechanical regulator has to be turned up. Also, it's not too easy to find an 8 volt battery charger these days.
Was there a specific application reason for an 8 volt battery to be manufactured? I dont know. As mentioned it was used a lot in larger 6V tractors that should have come from the factory with a 12V system in the first place.
8 volt batteries were intended for golf carts . Repair the 6V system or repair the electrical system and convert to 12V.
(quoted from post at 11:08:42 11/23/21) More power.
Replace the 6V lamps with LED, the extra voltage won't burn them out .
Ellis Kinney,
It is a way to avoid proper troubleshooting and effect the proper repairs. In a well maintained system, there is no need for an 8 volt battery.if you need more power, its much better to add a second battery OR a third in parallel if you like.
Nothing will need to change.
By the way you will need an 8volt voltage regulator if you go that route.
Guido.
I have to say if you putting an 8 volt battery in a 6 volt system ,your just trying to mask the issues of the six volt system of maintenance to it or the engine is tired and needs freshen up. Or they used to small of six volt to save money which never works .
Engineering for six volt systems was pretty good.
(quoted from post at 13:07:22 11/24/21) Wasn't that good or they would never have gone to 12V,6V these is like the horse and buggy it'll get the job done but a lot better ways around.
You are comparing a 6V battery and a 8V battery as being as different as a horse and buggy is from a from a car ?
No 6V and 12V those old 6V systems are as out dated as the horse and buggy.When was the last tractor or vehicle you've seen new with a 6V system? 12V one wire alternator and you're good to go.Why hassel with something that was problematic from the get go? I grew up using 6V tractors all mine are changed over to 12V.
