ron57
does anyone no how to fix my 801b case when u push in on cluch the gear will not stop u got to turn it off put in gear and direct drive dont work broke a fork in trans got a new one put in now it will not move brock the block 4 m0 ago put a new motor in now it does all this work ok be4
Should ask on the case forum, you might get better info there. Did you add hyd. oil to the com? If so that is probly your problem. Hyd. oil is to thick and the converter will drag. You should use pink ATF fluid in the com.
