8000 hydraulics
my remote hydraulic control valve are worn out. I want to install a after market control valve. What do you have to do to the manifold to get pressure for the new unit.
Hi Gordon I took the valves off my 9000, they just bolted down onto what they call a manifold on the CNH parts site I would call it a base block. the valves bolt down onto it so I just took them off and then bolted the cover plate down onto the base.I don't think that there were any threads so I don't know how you could get oil to go to an after market valve unless the holes lined up with the holes in the base.Good Luck.
I have a manifold plate on top of my control valves. I have a 5000 that you can buy a adapter plate so you can add an aftermarket control vale. Do they make one for the 8000 and 9000 series?
