8000 pto pressure test point.
I have a service manual coming for this beast but would like to start troubleshooting the pto. It doesn't turn on at all. (it might turn very slightly) the lever on the left side of the tractor does move up and down. This is a dual power. (sounds like that plays into it)
the story is someone put a new pto clutch in it - but didn't fix it.
sam
sam
Follow the small 1/4" line running from the side of the transmission to the rear axle. There should be a tee fitting of some sort at the end with hopefully a 1/8" NPT port in it that would allow you to do a pressure test.
thanks - left or right side?
