801-b Drawbar Roller
Case801-B
All,
Working on the rear-end of the '59 801-b and I have question about this roller unit (not sure of the actual name). As you can see it's flat-spotted quite bad. Can a guy:
1. buy a new replacement part # from Case?
2. re-purpose some other part to take it's place?
3. rebuild it by welding it up and grinding it round again ?
Any help appreciated
- Rodd
I doubt new ones are available and if they were the cost could be prohibitive. Welding up and grinding might be the most economical or if you know some one with a metal
lathe they could turn one out quite easily. Rod.
In stock, ready to ship!! $73.80.
http://external_link.com/product/case-400-700-730-770-800-830-870-900-930-970-1030-1070-1175-o6088ab-a27010-drawbar-roller/
I have fixed at least a dozen of them,, takes me maybe 15 min to do a couple bucks worth of wire and a few cents of a grinding wheel is not much I see zero need to put them on a lay for turning down easy to grind them true or it is for me anyway, did not know John had them I may look into a couple for the shelf,, all of the ones I have done are still nice and round
