801 Ford Tractor Hydraulic System
My 801 will not lift. What do I need to look for? Pump has pressure, has auxiliary hydraulic valve on it. It has pressure through the auxiliary valve ports. Thanks for your help.
Are you sure the auxiliary valve is in natural(hold) position when asking the three point to raise? Or you have a major leak on the inside. Pull the PTO shifter cover and have a look.
