yellowtail
I have a 1958 ford 801 tractor that quit running I have installed a overhauled diesel pump and reworked the fuel injectors. I cannot get it to
run it will run as long as I use starting fluid but as soon as it runs out of the fluid it will not fire. I have checked the fuel from the pump and it is getting to the injectors could this be a compression problem? It did set for a year or so after it quit running. I tried to check the compression but do not have a good set up and could only get about 75 psi.
