Last year I bought an 801 tractor it had some minor problems but otherwise was in good condition. One problem was hiccups on the lift. I rebuilt the top cover and the lift cyclinder.It still has the hiccups but will hold a load up for hours with the engine off.My question is ,could a diverter valve cause the hiccups,I can change the rate of them by turning the valve shaft in the body.The only leak I can see through the side cover plate is a squit out of the control valve every time it hiccups. I was thinking of getting a block off plate but not if the valve could not cause this problem. I use the tractor mainly for brushhogging, so not a big problem but it is annoying.
