801-powermaster fuel smoke problem
ron bowes
Hi
I have a 801 diesal that i just had the complete fuel system rebuit.pump and injectors,replaced all cylinders,pistons,rings,pushtubes,etc.My problem is when the tractors starts,it smokes with raw fuel all the time,checked engine timeing and pump timeing.No 1 cylinder on compresson stroke,18% on flywheel.both lines on pump alighned.Dont know whatelse to try.Any help.
Sounds normal to me, but I dont know Fords either. The few diesels, other than road idesels, I have had experience with all do that.
Ron,
It may be the pop-off pressure for the injectors is set a little too high. This will delay fuel delivery a little bit and will result in unburned fuel coming out the exhaust. If the pump has been rebuilt properly and the pump timing is correct, I don't know much else, unless the injector tips are incorrect, with atomizer holes too large diameter. My first tractor was an 801 with the 172 diesel and it started right up every time with a little black smoke but never unburned raw fuel--like the kind that'll burn your eyes and throat...if it weren't for a tree crushing it during hurricane Dennis, I'd still be using it...
Thanks to all for the information,had the pump rechecked and injectors.Pumpshop found nothing wrong,but there's something most deffintly wrong.
Thanks ROn
