806 706 front axle
BT in NE
I have a 1964 706 gas with a narrow front, and I know where an 806 diesel with a wide front is about to be scrapped. Will these interchange or is there more to it? I would like to put the wide front on my tractor as it has a loader. Thanks for any help. BT
Yes.As long as they are both Farmalls.That front will fit from M up through 1256.If you can,buy the complete tractor. There are a LOT of parts(trans;rear end;hitch;fenders;chassis.......) that will interchange
I would say snag at 806. Depending on why its being scrapped you could do a major upgrade to that d361. The front ends as well as everything behind the flywheel should interchange.
(quoted from post at 16:39:03 07/13/14) I would say snag at 806. Depending on why its being scrapped you could do a major upgrade to that d361. The front ends as well as everything behind the flywheel should interchange.
I SECOND THAT EMOTION!
