BudKaiser
I want to know where have yall purchased the best quality (for the price) seats for you tractors from. I want to put original complete seat ( with suspension) on my tractor. I replaced fuel pump and injectors,
fixed tach, fuel gauge and 3 point lift and it starts and runs good and everything works.
I bought a new one from Hy-Capacity, it was expenesieve 16 years ago,, i hate to think what it cost now, but it is just like the original! Good Luck
didn't know they had a suspension for the 06,56 series seats. Ours are the one that you adjust both height and distance with the lever in the notches or you push the lever and it becomes a standing position . Only suspension is the cushion on the wood.
Well CG you missed out then, see the link. Number 18 are the rubber puck deals that twisted to act as springs and number 27 is a shock, which I must say commands quite a price from the dealer at $155. This is what our 656 had. Unless you had a Wheatland model I suppose there is a possibility that they had no suspension on those. I do not know. And why you would not get it if it was available? A 39 Farmall H and everything following that had seat suspension except maybe some of the As and Bs did not but I think most had at least a spring. I am not 100 percent certain but I think even the F series like F12 & F20 had some type of seat suspension even if it was just a spring. Point is I would not know why the would offer suspension on all those early models and not and 06 model. The neighbors had a John Deere G and I am pretty sure it had no seat suspension just a board and cushion over the batteries. I guess something had to keep you riled up a bit so you could throw that hand clutch in with proper gusto.
806 seat suspension
Do a search on K&M Manufacturing, they make the best OEM seats, think you can order direct. I bought a K&M white Tombstone seat back in 2005 from Easy Bob's Tractor Parts,like what would have been on a 1256 when new,,
now known as Devon's Tractor Parts, phone 888-560-1466. You should be able to get the EXACT seat your 806 came from FARMALL with. The factory seat was made by Sears Mfg in Davenport, Iowa.
