Hello, I'm new to the board so I hope to learn a lot from all of your expertise and maybe you can have some patience with a newcomer. I picked up a 806 diesel with 7400 hrs on it and have a couple of questions. From what I can tell it is a 1965 ser. #5308. I have a leak at the injection pump looks like shaft seals. Pump #s are 33917 6-r92, 37168, 6c40105. Can I replace the seals without pulling the pump off? Or should I send it out to be done? I do have some mechanical ability but no shop manual. The othe question is on the left side of the engine there is a pipe for oil that has a 90 degree bend in it, the pipe is about 1 1/2 dia. it also has a o ring leaking, it looks like alot to come apart to get this pipe out. Any advice? Thanks for the help?
