806 Oil Leak
Anonymous-0
Going to work on an old 806 gas that is pouring oil out from under the radiator. Looks like hydraulic oil. Did they have a cooler or the steering lines routed through there? I would like to have the tune up specs since it will be in shop anyway.
Yes the power steering lines are there. Probably one of them leaking and hyd oil would be the oil. Take the grill out and you will see them. Might have to clean out the built up oil and dirt.
Mornin' Larry,
Pull the grill. You're probably gonna find those hydraulic cooler hoses leaking.
Allan
