806 Power Steering Leak
Shahn
My 806 has an intermittent oil leak under the steering wheel. It has only happened a couple of times but I expect it will get worse. I asked my CaseIH parts dealer if there was a seal that could be replaced under the wheel. His parts catalog did not show parts were still available. I checked old discussion threads and found one that said use IH part A47038. My CaseIH parts dealer does have this seal kit. When I checked an online retailer, I did not see the 806 listed under applications. Can anyone confirm if the A47038 seal kit will fit an 806?
You can.
Go to partstore.caseih.com, click on "Find Parts by Model", type "806" into the search bar, select "Farmall 806", select "Steering Mechanism", select "(J-10) Steering Mechanism, Hydrastatic Power Steering Hand Pump" and click on item #5 in the diagram.
Part number A47038 is correct.
