sonnythomas
- Location
- Bryant, Ill
1964 806 is coming along....Piddly things happen. Still won't start on it's own, but idles like a purring kitten and then with full throttle it roars like King Kong. At idle it will take off in high torque, high range and 4th (8th?) gear. We pulled a tree out of the ground using low gear at idle. Engine never sputtered. Tires dug in and chewed out the ground.
When we got started on the 806 we had to change fuel line around to proper alignment.
Hydraulic leak repaired and 7 gallons put in.
Replaced water pump (only took 376 miles). Wrong water pump twice and correct water pump leaked right off the bat. New water pump has a pressed on plate for the fan blade.
Schwartz front end - parts replaced and now steering like a Cadillac.
So we have the right brake leaking - another item to fix.
Bigger problem came today. Transmission leaking hydraulic fluid to clutch area.
Brother says we have to split the tractor to replace seal. Question; Could it be the seal dried out after 4 or 5 years sitting and could it revive on it's own?????
Splitting the tractor would mean IH/Case shop and around $1500 to $2000.
Is the 806 worth it? This will put me at $5000 invested.......
