806 valve leak
RustyR
So I finally took the hydraulic control valve apart last week that has been leaking for years, put a new pin and the four orings in it. Mowed hay yesterday and the darn thing still leaks as bad as it did. Any ideas on now what?? Leaks out of the snap in cap to adjust the detent.
did you replace the unlatching piston with the tiny o ring? the new one has to go in from one end- where the ID of the hole is chamfered so you don't cut the o ring
