820 2 cylinder front wheel weights
KNJL
Anyone have a picture or part number for original John Deere front wheel weights for 820 ? Front rims have bolt holes for weights so I assume weights where available for them . Anyone know about them ?
It looks like the weights in the picture bolt on with 3 bolts at the hub. The jd1276r front rims have 4 bolt holes in them , are the 4 bolt holes in the rim for an after market weit like f&h ?
If you inside the left wheel there appears to be 4 bolts. I have a set that are split and mount on the inside of the rim, with 4 bolts
Knjl,
If the front rims are mounted to the hubs correctly there will be 3 unused holes in the rim that line up with 3 unused holes in the hub. The 3 unused holes are used to mount the B2016R weight shown in the 830 pic.
The 4 holes you're talking about can be used to mount aftermarket weights.
