820 clutch leaking oil
820Art
I have a problem with a wee bit of oil seeping out of somewhere either inside the clutch or running along the outside and getting flung around by the belt pulley. The pulley is a bit wet on the engine side but the clutch is completely dry when I took the cover plate off the end of the pulley. So would that rule out an internal leak? Its not a big leak at all but it sprays little specs every where.
Remove the clutch clean the oil slinger and use a o-ring pick on the grooves. Also make sure the drain hole is clean and clear.
