820 Steering Problems
CHSchmidt
Still having difficulty adjusting power steering. I"ve been moving the block on the side of the steering column back and forth and cannot get it to steer correctly. Moving the block towards the back of the tractor makes the steering erratic and turns hard to the right. Moving the block forwards makes it do the opposite. Engine speed seems to effect it also. The faster the rpms the more violent and forceful the steering jerks. Should I replace the entire pressure block? Does any have a good used one for sale? Thanks Carl
Did you have the front axle jacked up? My dad had a 70 that needed the same attention. We jacked it so the front wheels were off the ground, and with the engine running, tapped the housing until the front wheels were pointing straight ahead. Cured whatever was ailing it.
The powersteering is VERY finicky to get adjusted, and you may be dealing with 50 years of wear, which will make it darn near impossible to adjust right.
I REALLY suggest that you get a powersteering service manual.
First...are you using the right fluid? Many people try different stuff, but most agree that the correct fluid from JD is the best way to go. It IS a special oil. Get the right stuff, at the right level.
The block you're adjusting is VERY sensitive. Make yourself a reference mark with a marker or punch...and then adjust in SMALL increments. It doesn't take much.
If your tractor is like my 80 was, you will need to just give the powersteering setup a good overhaul. Mine was worn too badly to adjust correctly.
Brandon
I am using the J.D. power steering fluid. I have attempted 25 times or more, making reference points and only moving it the slightest. I have tried it with the front end on the ground and off the ground. At idle, its not as bad. What part of the system did you rebuild? Thanks
Carl:
Moving that "block" is only used to center the steering, so that the actuator lever and spool valve are at neutral wheels are straight ahead. Other symptoms can probably be traced to the actuator valve which that block is bolted to.
What, precisely, are the symptoms after the block has been correctly centered.
Frank
I cannot get the steering centered. If I have erratic surging to the right, I try to adjust but then I'll get the same problem to the left.I make reference marks and barely move it,but never can get it centered
(quoted from post at 20:44:15 12/17/09) Still having difficulty adjusting power steering. I"ve been moving the block on the side of the steering column back and forth and cannot get it to steer correctly. Moving the block towards the back of the tractor makes the steering erratic and turns hard to the right. Moving the block forwards makes it do the opposite. Engine speed seems to effect it also. The faster the rpms the more violent and forceful the steering jerks. Should I replace the entire pressure block? Does any have a good used one for sale? Thanks Carl
Sounds like any other proportional controller, which it is. That has too much gain/amplification dialed into the set-up. Or so much wear/freeplay that control is no longer proportional.
Where is the flow control set at?
Do you have a JD manual or are you just winging it?
I'm just winging it. Don't know what the pressure is. I need to get a power steering manual. What I can't figure out is why the power steering started acting up after I overhauled both motors. It steered perfectly before, and I never touched anything with the steering.
