826 oil leak?
Bradford
I have an 826, it runs fine but after an hour or so oil is seeping out around that small plate on the clutch bell housing. It is not leaking out the bottom of the clutch bell housing just seeping pretty good from aroung the examination window where the plate is bolted on. I can"t tell if it is engine or hydraulic becuase i didn"t look real hard yet but the steering is also starting to work real good. what"s strange is it is two gallons low of fluid which i heard i should keep a gallon overfilled? Any ideas?
