830 jd battery help
ghunziker
When I purchased my 830 it had two twelve volts batteries. When I recently replaced them, I noticed from the manual that it showed a ground wire connected to the battery box. This was with four six volts batteries. Should I have a ground wire connected to the battery box for my two twelve volts batteries? Thanks for any help.
Ground wire to battery box or frame between each 12 volt battery is to supply ground connection for 12 volt accessories such as field lights, cigar lighter & fuel gauge. 1/2 accessories are 12 volt minus(-) & 12 volt plus(+) ground
