841 gas air filter maintenance
DRD in Pa
What is the best way to clean the air filter properly? And would soaking it in gas cause any harm to it? And finally what oil should i soak it in before putting it back in the canister? Thanks
If it hasn't been let go too long you are supposed to just remove and clean the bowl, and fill to the line with the same oil as you have in the crank case. If you can see that it has pulled a lot of dust up in to the steel media then you ought to remove the whole unit and clean it with oven cleaner and water solution. I would use hot water, give it plenty of soak time then rinse well and let it dry overnight before re oiling.
I remove the mesh and wash it out in gasoline.
There is no need to oil it before replacing it in the cannister.
Nearly always overlooked is the vertical internal air tube, which is almost certainly badly restricted with accumulated dirt. I use suitable tools to scrape most of the dirt loose before soaking the canister in gasoline.
Allowing the tube to become restricted will cause the engine to run overly rich at speed and use excessive fuel.
Dean
If I clean one I just drop the whole unit with out the oil cup in a bucket of gas. Let it soak for a few hours and shake it once in a while. Hang it up to dry out. Then put back on the tractor. I also then filter the gas very well and use it
petro solvent of your choice. i usually have excess diesel or mineral spirits laying around so that is what I use.
soundguy
I put the whole unit without the oil cup into a 5 gallon bucket and fill it so that all the mesh is submerged in diesel. I slosh it around and then let it sit over night. I then decant off the diesel, get rid of the dirt and repeat the process until no more crud finds its way into the bottom of the bucket. I hang it up and let it drain any residual diesel off and reinstall.
