In May of last year I bought a 841. The tractor started and ran fine all summer and fall. Around Thanksgiving had tractor out pushing with blade on way back to shed it started coughing and sputtering and missing. Left tractor sit for about 3 weeks. One evening pulled out of shed to put chains on it shut off and would not start. I thought it was a carb problem. Installed a rebuild kit in carb around Christmas with no improvement.Work and weather prevented anymore work on tractor until late January. I checked and had no fire at plugs. Replaced coil checked points has new distibutor and points. It still has no fire when cranking. Voltage at coil drops to 3-4 volts when cranking. Hooked up another battery to coil. Has fire when cranking with other battery hooked to coil. When work and weather here in PA permits will get back to working on tractor any help or advice on what else to check would be greatly appreciated. Thank You!
