8430 4x4 hyd
lindy
have a few questins about a 8430 4x4, is the range tranmission and the power shift share oil, how much is fluid is require, each if seperate, is their a low fluid or pressure light.
There are 3 places to check oil levels in an 8430...
1.) The engine crankcase. (Dipstick.)
2.) The front axle housing. (Check plug... and DO NOT forget this one or you'll be putting $$$$$$$$$ into the front driving axle!) (GL-5 90-weight gear oil.)
3.) The rear end/transmission/hydraulic system.
There's a dipstick at the back near the hydraulic couplers. Somewhere in the 20 - 30 gallon range of Hy-gard UTF.
There NO low fluid warning, but a warning light for low clutch pressure (which will occur if the "BLEM" in the driver's seat forgets to check the hydraulic oil)!
The warning light will also be triggered by low tranny LUBE pressure and most had or were retrofitted to a tranny lube pressure gauge.
If you're keeping it around you'd better get an OM, call Deere TechPubs @ 1-800-522-7448 or watch ebay.
